This widget could not be displayed.
VISA to read/write COM1
Dear all,
This is a simple example to test VISA to read/write my COM1, I have Labview 8.6 and even downloaded and installed the VISA441 again.
But it doesn’t read anything from COM1.
The error message is “timeout expired before operation completed.”
I appreciate for your help.
Raymond
(3,175 Views)
What are you communicating with?  Are you sure you have the right kind of cable between the two.  Between 2 PC's, you would need null modem cable.  Between a PC and another device, you might need a straight through or null modem cable, you would have to check the manual for the device.  Are you sure you have the correct communication settings?  Usually you would need a small delay between the write command and the read command to give time for the other device to read the command and turn around and send back a response.
Do you know what the return message is supposed to look like?  Does it need a termination character such as a line feed or CR/LF?  How are you running this VI?  It is set up as a one shot VI.  Are you using the Run Continuously button to run it?  I hope not.
You should really look at the examples in the Example Finder such as Basic Serial  Write and Read.
(3,165 Views)
May be the "byte count" have a wrong value or the "VISA Read Timeout Property" is too small.
(3,164 Views)
Ravens Fan is right. Check out the shipping example found in example finder called "Basic Serial Write and Read.vi". This is a simple serial VI that shows the delay needed for some communication. Give it a try and let us know what you find out. Good Luck!! Thanks Ravens Fan!!
(3,117 Views)
