VISA speed
I am trying to control a GPIB using an VISA VI however there seems to be a time delay (tenth of a second) between the control value from my program and the corresponding change in the value on the
controller. Is this delay intrinsic to the communication system (hardware or software) , if no how can I decrease it. I have attached the code for reference. I want the values to scan through in a milli-second instead of a second.
The  controller is a laser diode controller  (model LDC-3714B)
Ams
(3,077 Views)
hello Ams,
i don't think visa is the cause, stop working with this programming "concept" or you 'll spend exponential time en nrj for nothing...
Have a look on state machine file -> vi (new...) and look for state machines template and also events structure
https://www.ni.com/en/support/documentation/supplemental/16/simple-state-machine-template-documentat...
https://www.ni.com/en/support/documentation/supplemental/06/event-driven-programming-in-labview.html
have fun
Best regards
Tinnitus
 NB : i think NI sould hide stack sequence in the deepest possible palette it will avoid beginners starting with the worst existing structure...
Message Edité par tinnitus le 04-21-2009 06:46 PM
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(3,068 Views)
Ams,
If you are looking for a performance increase the first place I would start would be to get the Write to File operations out of you main loop and implement something like a producer consumer design pattern.  A helpful document here.
Sincerely,
Jason Daming
http://www.ni.com/support
(3,029 Views)
