VISA serial
I have LabVIEW6.1 with Win2K OS. Somehow, VISA doesn't recognize serial ports. Not all but some. Then I installed VISA RT-engine and it fixes most of unknown port issues (still remain some unknown ports). Then I reboot my pc, it all messes up again. First it doesn't recognize 5 ports, then 7, all different ports. How do I fix this problem? This is really driving me crazy as I thought it is fixed, then the same problem comes back again. Thanks for your help!
Danny
(3,611 Views)
Hi Danny,
Are you able to "see" the serial ports within MAX (Measurement & Automation EXplorer)?
I also use multiple COM & LPT ports.
I don't think the problem is related to LV6.1 and VISA not recognizing the serial ports.
Do you see the serial ports in the Device Manager (Control Panel > System)?
It is strange that they appear to disconnect after rebooting the PC.
They should all appear in the Hardware Device Manager, if not, re-install the drivers, some of the driver installation require to be installed in multiple instances (ie: two steps per port!). Although it seems like the installation takes forever, you have to go to the end of the driver installation (even if it seems "stuck" in a loop).
If all the ports appear in the Device M
anager, verify that they all appear in MAX. If they don't, scan for them.
Open MAX, expand "Devices & Interfaces", expand "Ports", and look at what is listed. Since my ports always showed up, I have never tried right clicking "Ports" and selecting "crease new statuic serial port".
Hope this helps,
JLV
(3,611 Views)
