VISA serial issues
Recently, I would sa within the last month or two an infuriating problem has cropped up on ALL of my target machines that are Windows 7 or higher.
The serial ports, be they actual hardware add in cards or USB adaptors with virtual serial ports just randomly "disappear" and any LabVIEW program using them gets a timeout error.
The only way to get these ports "back" is to reboot the computer.
This even affects program that have been running 24/7 for months on end without error, now they could error out several times a day or run for days without issue. NO LabVIEW code has been changed on these systems!
Is anyone else fighting this or similar issue?
=== Engineer Ambiguously ===
(3,147 Views)
Check windows power settings for your usb com ports. Make sure power saving mode is disabled. Windows may be turning off. USB_PS.png
(3,140 Views)
That's worth looking at, but he said it was happening on actual hardware ports as well, which I would take as real physical DB9's either on the motherboard or on a PCI card as opposed to USB based.
(3,120 Views)
