VISA read timeout error at high sampling rate
I use VISA Write to send the command "FAST2" to an SR830 lock-in amplifier, which then send data to a GPIB-USB-HS cable connecting to the computer. I use a loop to performing VISA Read again and again to receive data from the cable. Each time 4 bytes data are received.
The program performs well if the sampling rate of SR830 is set to 256Hz. However, when using 512Hz, I got "error -1073807339: VISA:  (Hex 0xBFFF0015) Timeout expired before operation completed."
Any comments will be appreciated.
(3,238 Views)
The 4 bytes you are looking for did not arrive at your port before it timed out passed.
You are reading faster than the stuff is getting to the com port
  • Check for bytes at port before reading.
  • Set the time out longer
Omar
(3,206 Views)
Have  you solved the problem? I meet the same problem now.
WT
LV2013
(2,836 Views)
Dear Weitong,
This thread is 7 years old and has only two previous posts - you might receive better help by creating a new thread of your own. When you do so, please describe the problem you're having and upload your VI so that we can take a look at what you're doing.
GCentral
(2,831 Views)
