VISA Write Error Code -1073807298
For some reason I am getting an error code in LabVIEW when I try to write a serial command. I have always used this structure when writing SPI commands and have never had a problem or error until now. The code will execute the first SPI command but it does not fully write the following commands if I were to put something to follow the first (see image 2, it doesn't execute 0A01). I know this because I am using code to turn on and off an LED.
Like I said, I have never had issues like this before. I've run numerous tests this way and have made no changes.
Please help! I use LabVIEW and this structure in particular to automate our test equipment at work and I have a deadline to meet soon.
Thank you.
Message 1 of 1
(455 Views)
