VISA Wizard for fireware
I am using the visa wizard drive to make a driver for my pixelink camera that is driven by Firewire.  The problem I am having is when it comes to the Unit Specification ID and the Unit Software ID.  I tried going under the device manger, I go to the imaging device, but the camera under it's tab doesn't give any kind of ID's.  I was wondering how I get those ID's?
guilio
(3,469 Views)
Hi guilio,
Unfortunately, that information is unit specific and you need to get that from camera manufacturer.
Please look at the following link for a different discussion forum.
http://forums.ni.com/ni/board/message?board.id=140&message.id=22508&requireLogin=False
Sammy Z.
(3,438 Views)
I just got it working yesterday evening.  I couldn't use the IMAQ itself, but needed the IMAQdx installed.  From there, Labaview picked it up immediately and I was able to begin use.  What I was told is that if Labview didn't pick it up, you would go into device manager, select your firewire camera, and then update the drive with the IMAQdx driver, then labview would pick it up in the MAX.
guilio
(3,425 Views)
