VISA Read won't return data in case of timeout?
Hello!
I just want to verify if this is expected: when using VISA Read with eight bytes while the message coming in only has six bytes it causes a timeout and an error (VI_ERROR_ABORT). I can see in the IO Trace that the six-byte message is received, but it's not returned via the output of VISA Read.
Normal?
(1,018 Views)
@MaSta wrote:
Hello!
Normal?
Yes, when VISA returns an error it won't remove the data from the incoming buffer. The data is still there and you should be able to read it with a properly configured VISA Read.
Rolf Kalbermatter  My Blog
(998 Views)
