VISA Read not working
I am stuck with my LabVIEW code, that I made for controlling my power supply. I am able to go to remote mode on/off, and switch on/off the output power. But I am neither able to set the voltage nor record the power from the power supply. It seems that VISA read is the problem. Please help.
Please note - as some of the suggestions on this forum that I already have tried for example removing the property node when I am using the termination character, this doesn't work.
I have attached my code.
I would really appreciate any help.
Message 1 of 10
(3,367 Views)
Please attach your actual code instead of images. And don't use Bytes at port to read VISA, either termchar (if applicable) or fixed number of bytes. According to command "power?\r\n" i'd say use termchar with "\n" as the character (0x0A).
Message 2 of 10
(3,353 Views)
Accepted by topic author Win_PhD_2023
1. Why are you trying to perform a read after setting the voltage?  That is unless the supply gives a reply after you set it.
2. DO NOT USE THE BYTES AT PORT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (still not enough emphasis)  You seem to have a clear ASCII based protocol here.  So just tell the VISA Read to read more bytes than you ever expect in a response and it will stop reading when the termination character is read (defaulting to a Line Feed).
Message 3 of 10
(3,348 Views)
Term Char is not working, Its giving some error in VISA CLR. But Thanks though for trying.
Message 4 of 10
(3,336 Views)
And what is that error?  There is also the argument you shouldn't even need the VISA Clear.
Message 5 of 10
(3,332 Views)
A strong argument.  You only need that "in the middle" if you are doing something wrong!  In this case, it might even be what is messing up the communication.
Bill
CLD
(Mid-Level minion.)
Message 6 of 10
(3,325 Views)
Is this what you meant? It didn't work though...
Thanks anyway
Message 7 of 10
(3,300 Views)
Thank you so much I removed the property node altogether and VISA CLR [Suggested by other user]. Now code works.
Message 8 of 10
(3,295 Views)
Thanks anyway
Did you eliminate the Read after setting the voltage?  The large majority of instruments do not reply with anything when you set a value.  They will only reply if you perform a query.
Message 9 of 10
(3,290 Views)
Thanks a lot, after removing VISA CLR it worked.
Message 10 of 10
(3,287 Views)
