VISA Read error while transferring points from oscilloscope
With the program attached, I am transferring waveform data points from an Oscilloscope to the LabVIEW front panel through numbers and a waveform chart. Everything works fine, but I am getting an error at VISA read:
"Error - 1073808339 occurred at VISA Read in Test program 4...possible reasons: VISA: timeout expired before operation completed"
I realized that from particular VISA read, I am not reading any data nor is there a return count. Any tips to fix?
(1,581 Views)
Hi Daacos,
The usual answer to this kind of question is: "Read the manual of your scope (carefully)!"
On your VI:
  • right-click the string constants and select "Size to Text".
  • right-click the string constants and select "\-code display". You may even make the display mode item visible.
Now read the manual and make sure each command is sent with the (maybe!?) required "end of line" constant
(1,574 Views)
Hello there,
I double checked the program and looked at the manual, and everything looks right. The format of commands also seem correct and I tried troubleshooting but nothing solved the error. Any other suggestions?
(788 Views)
It looks like you are missing a termination character on the CURVe? command.
Turin on the " '\' Codes Display" and look at your two SCPI command lines.
=== Engineer Ambiguously ===
(771 Views)
