VISA Read Status Byte Timeout in .exe
Hello all,
I am communicating with a device over GPIB in my labview project.
The code works fine when my project is all VIs (it's a large Actor Framework project), however, when I compile my project to an executable and begin reading from the device, my program always timesout at: "VISA Read STB"
Why? Can anyone shed some light on why I might be timing out on this in the executable version but not on the VI version?
(2,335 Views)
When you build your exe, enable debugging on the build.  Then you need to run the exe from a remote panel using the Labview menu "Operation" / "Debug Application".
This will allow you to connect to your exe and run it using a BD to debug.
(2,282 Views)
Is the executable version running on the same computer as the VI version?
(2,269 Views)
It turns out that the issue was that on the deployed PC, it was using an old PCIe-GPIB card, which apparently couldn't handle the fast reading?
I was debugging on my "source code" PC with a new USB-GPIB-HS+ and it had no issues. I then went to the deployed PC, used the USB-GPIB, and everything worked fine.
Seems like its time for an upgrade...
(2,231 Views)
Your "old PC" has PCIe-GPIB, its the GPIB that can't handle the fast reading... PCIe is fast.
I can tell you, USB-GPIB adapter is not supported for a few years now since (I think) LV2016. USB-GPIB HS+ ($1200USD) is supported.  But you say your deployed PC (old or new?) is using USB-GPIB and it worked fine.
Just curious, what USB-GPIB and what LV worked fine?
(2,222 Views)
I know PCIe is fast, but this was an old PCIe card (and not HS+). It still doesn't make sense to me why it wouldn't work though...
As I said in my previous post, I am using the GPIB-USB-HS+ and it works fine, but not with the PCIe card.
I am using the latest version of LV2020 and I am using this GPIB-USB-HS+.
(2,184 Views)
