04-28-2016 05:56 AM
Hello ,
This error message came in the Visa interactive tool : VISA: (Hex 0xBFFF001D) The specified attribute is not defined or supported by the referenced resource.
what should i do to fix it ?
Thanks !
regards ,
bibo702
04-28-2016 07:19 AM
04-28-2016 07:38 AM
Mike ,
I cant do any modification in this window . how should i proceed ?
regards
bibo702
04-29-2016 03:27 AM
Hi bibo702,
you try to set a timeout for a PXI-1031 Chassis. A PXI chassis doesn't support a timeout value.
It is not possible to set a timeout, independent of the software you are trying to use.
Stephan
