VISA Error Help (-1073807360)
Hi.
I cannot communicate with instruments via GPIB using VISA functions in
Labview (VISA Write/Read). However, when I use GPIB Write/Read, it
works just fine. I am using one NI PCI-GPIB, so I know it is Board0.
I am also sure that I am typing the VISA sessions in correctly
(GPIB0::16::INSTR).
I go to MAX, and it tells me:
Error Code -1073807360 ViStatus returned from VISA function call
Descrption viOpenDefaultRM returned 0xBFFF0000
Thanks in advance for any input.
Bill
(3,558 Views)
Your suspicion about incorrectly typing the VISA session is probably correct. Try "INSTR::GPIB0::16" or just "GPIB0::16", they should both work.
(3,558 Views)
John:
By the way, "INSTR::GPIB0::16" is invalid syntax and would not work.
I've posted some other suggestions in a separate response. I just wanted to address the resource name issue here.
Dan Mondrik
Senior Software Engineer, NI-VISA
(3,558 Views)
