VIPM-batch process eror
help me because i cant installer the arduino-labview toolkit and i cant for this problem 😕
Message 1 of 15
(11,803 Views)
Launch LabVIEW 2013.  On the Tools menu select Options.  In the list on the left hand side select VI Server.  Scroll down to Machine Access.  in the input field on the right type in localhost and select the Allow access radio button.  Below the Machine Acess List select ADD.  Select OK.  Now you should be able to run VIPM.
Kelly Bersch
Certified LabVIEW Developer
Kudos are always welcome
Message 2 of 15
(11,788 Views)
thanks bro 🙂
Message 3 of 15
(11,778 Views)
the error was continuous 😕
Message 4 of 15
(11,765 Views)
Verify that your Exported VIs list (just below the Machine Access list) contains an asterisk (*).  If not, add that.
Kelly Bersch
Message 5 of 15
(11,758 Views)
You may need to restart LabVIEW after making the changes.
Kelly Bersch
Message 6 of 15
(11,756 Views)
he error is still continuing and no longer have to do to download toolkits 😕
please help
Message 7 of 15
(11,727 Views)
I've given all the help I can.  Try contacting JKI, the author of VIPM, and see if they can help you.  Their email is info@jki.net or you can use their contact form at http://jki.net/contact.
Kelly Bersch
Message 8 of 15
(11,708 Views)
Accepted by topic author sacg94
Hi
Try folllowing this wiki from JKI.
Adding the extra addresses to the Machine List helped me Smiley Happy
Cheers
Patur Sivertsen Vase
www.hfjensen.dk
Message 9 of 15
(11,624 Views)
That‘s good,following your step I have solution problem,thank you!
Message 10 of 15
(10,395 Views)
