VIPM and vi.lib
Hi all,
I am starting to explore the tools within vi.lib.  Is there a way to use VIPM to put all the tools from the built-in vi.lib on to the pallette?  How do I keep the vi.lib in source safe if all my source safe file must fall under C:\TFS?  I am asking that because people in the team may make changes.
Yik
(2,709 Views)
Yes it is possible . Create a new project in the configuration Management and add the vi.llb (probably with a rename to avoid it from being getting conflicted from the actual files present in the vi.llb itself) using the add files options. (before that create  C:\TFS and link this folder to be used by the CM)
Regards
Guru (CLA)
(2,699 Views)
Thanks, Guru.
(2,680 Views)
