VIPM, MacOS, LabVIEW 2021 - Can't install some packages
VIPM wasn't working with LabVIEW 2021 MacOS, but someone in my company saw that we need to execute:
sudo chmod -R 777 "/Applications/National Instruments/LabVIEW 2021"
After that, most packages where able to be installed via VIPM.  However a few packages had issues.   For instance, MGI Panel Manager as is shown in this screenshot.  Any suggestions?
(1,162 Views)
Apart from verifying that the TCP settings were lined up in VIPM and LV,
I added the following to the above and it worked for 2021, 2022, & 2023 on x86_64 and Apple Silicon (M1 Pro):
sudo chgrp staff /Applications/National\ Instruments/LabVIEW\ 2021\ 64-bit
sudo chgrp staff /Applications/National\ Instruments/LabVIEW\ 2021\ 64-bit/{vi.lib,vi.lib/addons,vi.lib/_probes,help,examples,examples/exbins,project,project/errors,resource/Framework/Providers,resource/dialog/QuickDrop/plugins,templates,ProjectTemplates,ProjectTemplates/MetaData,ProjectTemplates/Source}
sudo chgrp staff /Applications/National\ Instruments/LabVIEW\ 2021\ 64-bit/menus/Categories/Computer
sudo chmod g+w /Applications/National\ Instruments/LabVIEW\ 2021\ 64-bit/{vi.lib,vi.lib/addons,vi.lib/_probes,help,examples,examples/exbins,project,project/errors,resource/Framework/Providers,resource/dialog/QuickDrop/plugins,templates,ProjectTemplates,ProjectTemplates/MetaData,ProjectTemplates/Source}
NB: For me,
as recommended in the below reference fails, throwing an Error Code 8 which itself suggests the folder path above "...menus/Categories/Computer" as a solution.
Reference:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000001DoXACA0&amp%3Bl=en-US&l=en-US
(604 Views)
