VIM which breaks with a cluster containing more than two elements
Anyone know how to make a VIM which will break if it is wired to a cluster with anything other than two elements in it (Not necessarily the same elements)
Use case:
A VIM which converts an array of clusters to a map. See attached.
(1,348 Views)
Accepted by topic author Worle
Try this:
I haven't tested it super duper thoroughly but it seems good so far. There could be some weird corner cases with clusters of other clusters, or clusters of variants, etc but it seems to work OK for normal datatypes.
Edit: I tried a couple weird ones, like a 2-element cluster containing a string and another cluster that itself contained a string and a variant, and it seems to work.
(1,323 Views)
That is spot on. I would not have ever thought of doing that!
(1,271 Views)
