03-30-2013 09:47 AM
Hello everyone,
I am a beginner to LabVIEW. I have to make a VI to plot a cycle of sine waveform with amplitude=1V, f=50 Hz and phase=45(in degrees). I have made the attached VI. But this is giving wrong results. I have converted all the values to radians and used while loop as per the question. Please someone have a look at my VI and please tell what is the problem.
I also wish to ask: In each iteration of the while loop, a value is passed to the waveform chart to plot corresponding to the value of t (time) which I have incremented in each iteration by a unit degree(converted to radians) upto 2*(pie) radians. Will the plot on the chart be corresponding to the values of t as per every iteration or the chart will follow the default way of plotting for t=zero and then incrementing by one. How can we control this thing?
Please reply soon.
04-04-2013 12:36 AM - edited 04-04-2013 12:50 AM
(This part is not related to LabVIEW)
First, it doesn't make sense to convert 't' into radians. Think of the units: A sine wave is represented by sin(ωt+θ), where ω is [rad/s], t is [s], and θ is [rad]. So, when multiplying, ω*t is [rad/s * s] = [rad].
In your code, however, w*t is [rad/s * rad] = [rad2/s] -- wrong units.
Secondly, remember that in a computer, you're dealing with discrete (sampled) waveforms. Ask yourself:
If you're not asked to use a specific sampling frequency, just pick one that's much greater than 50 Hz. (In your case, 1 kHz is a good sampling frequency) Then, answer the 3 questions above and see if it becomes clearer.
(This part is related to LabVIEW)
Right-click the chart -> Properties -> Scales
If you set the "Multiplier" of the X-axis to your sampling period, the chart will convert the sample-number back to seconds
