VI self-reference
Hi!
I work with LabView 6.02 and would like to get a reference to the current VI inside it
(like "this" pointer in C++). Is there some built-in way to do it or do I need to open reference
to the VI itself using it's path ?
Sincerely,
Sergey.
(3,813 Views)
If you drop a VI invoke or property node on the diagram leaving the ref input unwired, the node will implicitely apply to "this" VI.
Jean-Pierre
LabVIEW, C'est LabVIEW
(3,813 Views)
A little bit of caution, however. If you intend to open a self-reference in order to keep the VI running Top Level in background, use an explicitly opened reference. Implicit refnums are different from explicit refnums as thay do not keep a VI in memory if its panel is closed.
Jean-Pierre
(3,813 Views)
I've tried it, but got a "Not a refnum" error message. I saw this solution in DejaNews
archives of 1999, but then it was related to LabView 5. Maybe it's different in 6i ?
Do you have a working example ?
Thank you,
Sergey.
(3,813 Views)
Ooops, now it does work !
"Sergey Rosenblum" wrote in message news:9s9go6$q3l$1@news.huji.ac.il...
> Thank you,
> Sergey.
(3,813 Views)
As Jean-Pierre said, just drop a property or invoke node on the diagram. You just need to make sure you change the "VI Server Class" from "Application" to "VI" by selecting "Select VI Server Class>>VI" from the pop-up menu.
Brian
(3,813 Views)
