VI corrupted
I was working on a project suddenly my screen started cut from middle. I am currently working on LabVIEW 2016. Anyone have idea what should be the reason and solution also.
1st one is the corrupted
Message 1 of 10
(1,864 Views)
Hi Ankush,
Idea: are you using any splitter bars?
Solution: get an older working version from your SCC repository! (Or from your backup.)
Edit:
What exactly were you doing when you were "working on a project"?
Message 2 of 10
(1,841 Views)
Looks like you created horizontal splitter bars and hid them. You can right-click on the splitter and remove them.
Certified LabVIEW Architect
Message 3 of 10
(1,835 Views)
No I didn't used the splitter bar. I was working on UI modifications. I am using tab control for different screen design. If I went back to working revision then also after sometime same issue arrises.
Message 4 of 10
(1,825 Views)
I am using tab control, not splitter bar. I am working on UI modification when this issue arrised.
Message 5 of 10
(1,823 Views)
Hi Ankush,
So what are YOU doing "after sometime"?
What do you change?
Which modifications?
What's inside the tab?
What are the settings for each and every frontpanel element inside the tab? (Any scaling etc.?)
It's very hard to help you when you refuse to provide substantial information…
Message 6 of 10
(1,821 Views)
What was the exact UI modification that triggers this issue?
Santhosh
Soliton Technologies
Message 7 of 10
(1,813 Views)
I cannot see any "tab control". Looks like your top row buttons are floating over another structure and you might have changed the Z order and they moved behind. Once you attach your VI, we can narrow things down.
Also, what is the size of the front panel and where is the origin?
Message 8 of 10
(1,766 Views)
Sorry GerdW,
I was not active due to some project, I only placced controls and indicators inside tab and used clusters of controls and indicators. One thing I observed sometimes extra unused controls or indicators which I dragged from tab and placed in the free space outside screen area that causes this issue. Once I deleted one of the controls and issue resolved but after sometime same issue again arised.
Ankush
Message 9 of 10
(915 Views)
Sorry Santosh,
Ankush
Message 10 of 10
(911 Views)
