VI cannot be saved after editing lv_new_vi.vi
After editing lv_new_vi.vi, I can no longer save the new VI....
Plus, the asterisk * that appears in the title bar of the edited VI does not show up.
How can I fix this?
If anyone knows, please let me know.
I attached the error message and the image of the contents of lv_new_vi.vi.cannotsave.PNGLV_NEW_VI.PNG
Message 1 of 8
(2,250 Views)
Looks like you're running a non-English OS version and hence the file path contains a Japanese Yen symbol instead of a slash.
Please use a proper path to save the file.
Santhosh
Soliton Technologies
Message 2 of 8
(2,243 Views)
Thank you.
But when I rewrite the path constant from "C:¥" to "C:\", Labview will add "¥" on its own to become "C:¥\".
Is there a setting to change this?
Message 3 of 8
(2,231 Views)
Try turning on slash codes on your constants and front panel controls so that you have better control over what you are doing.  Just remember the slash code for a "\" is "\\"  Thus c:\ in slash code would be c:\\
Message 4 of 8
(2,202 Views)
It still doesn't work.
I cannot remove ¥ from the path, and I cannot create a new VI from a template with a path that has ¥ and \ mixed in.
If I enter a path with only ¥, I can save the new VI opened by running lv_new_vi, but I cannot save the new VI opened by Ctrl+N.
Message 5 of 8
(2,159 Views)
Sorry. I realized that all the backslashes I thought I had typed were regular slashes.
It seems that only the ¥ symbol can be entered in the path in Japanese OS.
The half-width ¥ mark and the half-width backslash are the same character code, so I don't think that is the problem.
Message 6 of 8
(2,149 Views)
Now I can save it!
I needed to specify the application instance.
https://forums.ni.com/t5/LabVIEW/New-VI-default-window-size/m-p/4139689#M1193218
However, I still don't know how to display the asterisk to indicate that I have edited the file.
Message 7 of 8
(2,133 Views)
I ended up using this to change the VI to open with "Ctrl+N".
I don't know why, but the asterisks also show up correctly before saving.
quick create a new vi from template - *Uncertified* - LAVA (lavag.org)
Message 8 of 8
(2,003 Views)
