VI Server
I'm using the VI server tool to dynamically load a secondary VI, from a
top level VI at the press of a Boolean in the top level VI. Execution then
passes to the secondary VI which runs until done, I control when it finishes
execution by another Boolean at which point the secondary VI closes down and
execution passes back to the top level VI. This works fine, the only
problem I have is that I want to construct a third level VI which operates
on request from the secondary VI, in the same way as the secondary VI
operates on request from the top-level VI. I have tried to implement this
but when the secondary VI is running and open and I press the Boolean in
that VI to transfer execution to the third level VI the application just
seems to h
ang. Could anyone shed any light on this problem?
Martin.
(3,285 Views)
Did you check to make sure the third level VI is configured to
show its front panel when called? It sounds like the 3rd VI is
running without showing its panel.
* Sent from RemarQ http://www.remarq.com The Internet's Discussion Network *
The fastest and easiest way to search and participate in Usenet - Free!
(3,285 Views)
