VI Server
How can I change the port of the VI Server without to go on the options of
labview? Like a configuration VI that I made?
Eric Poirier
(3,589 Views)
Before opening a vi reference, open an application reference and wire the port you want to it, then pass this reference to the vi reference open.
Hope this helps
(3,589 Views)
I think I have to explain more myself.
I made a server application who use VI Server. But I have to make a
configuration pannel to change the Exported VIs, IP access List. These
things are ok! But I can't configure the IP and other things who are in the
VI Server configuration in the options menu. So if anyone know how...
Eric
(3,589 Views)
There are no application property to do this.
The only way is to rewrite the appropriate keys in the application ini file
such as
server.tcp.port=6578
and relaunch the application.
Jean-Pierre Drolet
Scientech R&D
"Eric Poirier" a écrit dans le message news:
3b1e8166@newsgroups....
> Eric Poirier
LabVIEW, C'est LabVIEW
(3,589 Views)
