VI Server and LabVIEW Mobile
I have a Symbol MC9060 device running Windows CE.net 4.2 which will be hosting a client application that connects to a host (Windows XP), running a LabVIEW 2010 application, through VI Server.
I'm having trouble opening VI references from the PDA to the host.  I have a dozen VIs that i need to call from the PDA (through VI server) and so far, i haven't been able to open VI references to those VIs when the VIs themselves are part of a library (.lvlib).  In the labview project, if i move the VIs out of their parent library so they are directly under the "My Computer" target and no longer in any library, i am able to open VI references no problem.
example:  This is the VI path i am passing to the "Open VI Reference" VI path input when trying to open the VI reference when the VIs are part of the library.
IP: TCP::192.168.1.100
Port: 3415
Path: Library.lvlib:Main.vi
Like i said, the work around so far was to move the VIs out of "Library.lvlib" to a virtual folder, directly under the My Computer target.  In that case, i use the following VI path to open the VI references:
Port: 3415
Path: Main.vi
Is it possible with LabVIEW Mobile to open VI server references to VIs that are part of a library? If so, what do i need to do to make this work?
Thanks!
Erls
(2,378 Views)
Erls,
I will look into your issue on monday, thanks for bringing this to our attention.
<Joel Khan | Applications Engineering | National Instruments | Rice University BSEE>
(2,359 Views)
