VI Reference in a LLB
Just a quick question from someone who is fairly new at using LabVIEW...
I am trying to create a VI reference, and I am using the "Open VI
reference" VI (built in). How do I reference a specific VI that is inside
a .LLB file? I am opening the reference from a VI that is NOT in the same
LLB. Thanks in advance.
-Matt
(3,162 Views)
You need to have a path to the VI. LLBs are valid elements of paths, just
like directories. If you need to construct a path, you can use one of the
constants in the File palette, Strip Path to remove elements of a path,
and Build Path to add elements to the path.
Greg McKaskle
(3,162 Views)
