VI Protection
Dear All,
I want to know if it is possible to protect the block diagram with multiple passwords saved in the database and to check if the taped password excites in the database . I want this function to work even when the VI is not running.
Best Regard.
(2,288 Views)
Hi Emna,
LabVIEW itself only supports one (1) password when protecting the VI block diagram. Point.
(2,246 Views)
Why do you want this? Tell us more about your use case.
Are you expecting better security? More passwords will not give you that. Or do you need different access levels? Or access-groups?
Certified LabVIEW Architect
(2,198 Views)
thank you for your response,
I have a group of people who are using the same vi to make such modifications, I want to track the use of the VI and the modification that has been done by every person.
Best Regard.
(2,157 Views)
Best Regard.
That's typically the task of a properly configured source control system. You can't really control what a user does on his computer but you can control what he is allowed to do on the central repository and when she/he checks in modifications you can track each of them down to the user who did them.
Rolf Kalbermatter  My Blog
(2,152 Views)
@rolfk wrote:
...That's typically the task of a properly configured source control system. You can't really control what a user does on his computer but you can control what he is allowed to do on the central repository and when she/he checks in modifications you can track each of them down to the user who did them.
Search for "Source Code Control LabVIEW", and "Software Configuration Management LabVIEW".
(2,137 Views)
