Hi all, I've got two almost identical sub vi front panels that I'm dumping to a jpg image for reporting purposes. One was copied and slightly modified from the other to show a different data set and plot. The original works just fine, but the second sub vi, when using the "Front Panel:Get Image Scaled" method to pass the image to write the jpg, always returns the following error:
"Error 17 occurred at Invoke Node in Myprogram
Possible reason(s):
LabVIEW: Not enough memory to manipulate image.
NI-488: Unrecognized command.
Method Name: Front Panel:Get Image Scaled
[Continue] [Stop] "
I've stripped the problem section into a simple tiny new that only opens the report and tries to get the image with the same working/non-working result above. Using the Execution Trace Highlighter, it error is definitely occuring when the Method executes.
Any ideas? Thanks.
