VI Logger Lite
Hello. I am using USB 9211 and VI Logger Lite to log temperatures of my furnaces. How do I get the data in VI Logger Lite so I can plot the data with another application? Thank you for your help!
(2,736 Views)
Hello Elsa,
With VI Logger Lite, you can very easily export the data to Excel.  If you click on one of your tasks to get to the configuration dialog, you will see a Data Export section.  You can check View in Excel when task stops to do just that.  You can also right click on a data set after you have already run a task, and click on View in Excel.  For more information, see the VI Logger Help.  Hope this helps!
(2,719 Views)
