VI Interface Type
When I connect a strict VI reference to a property node, I see "VI Interface Type #" on the node. Why? What does it mean? How many numbers are possible?
Example:
(6,989 Views)
It just appears because it's a strictly typed VI reference so the connector pane of the VI must match the VI. The interface type just refers to the arrangement (e.g. inputs/outputs) of the connector pane - different connector panes will have different interface types. I think the number of types depends on the number of different types of VI connector panes (on your block diagram? or strictly typed VI references?). A non-strict VI reference could have any connector pane arrangement.
I think you can change it from either the start asynchronous call or the strictly typed VI reference - it'll allow you to select different interface types.
(blog)
(6,978 Views)
Hey random question.  Where did you get that ring type def constant that is wired to the open VI reference?  That seems like a neat thing to have, and have be built as a constant to the options input.
(6,921 Views)
The enum data represents the VI options for this method, x80 is one option we use
(4,698 Views)
I’ve shared an XNode for that.  I think it’s called something like “Named Numeric Constant”.
(4,693 Views)
Or maybe it was something like “Numeric Constant with Named Bits”.
(4,687 Views)
