VI Dynamic Callers
Hi all.
I have some sub-VI that running dynamically by different VIs. I need to know what VI launch sub-VI.
(2,747 Views)
I don't think there is any built-in way to do this, because the Callers property only returns non-dynamic callers.
I think you will have to do this yourself. For example, you could have a string control (which will hold the calling VI's name) inside the called VI and use Set Control Value to set it from the calling VI.
___________________
Try to take over the world!
(2,742 Views)
