VI/Application Memory Footprint
I have a question about analysing the memory usage/footprint of a LabVIEW application.
I am aware of the DETT and the VI Timing/Memory profiler but they seem to only show the memory used/allocated in the data spaces for the VI - and not the memory usage of VIs loaded into memory themselves (e.g. preallocated clones, shared clones etc.).
I have quite a large application and after loading the top-level VI when I run it the memory usage of LabVIEW.exe increases by about 1GB. This stays in memory until I close the front panel of the top-level VI. This is similar when the application is built into an executable - it uses about 1GB of memory when launched.
Is there any way/tool to help determine which VIs/clones are taking up the majority of the memory footprint? I know I can disable parts of the application to help narrow things down but I was wondering if there was another method I had missed.
Thanks in advance.
(blog)
(3,033 Views)
Does the "Metrics" property help?  You might need to "attach" this within the VIs you want to test and log the values ...
(3,011 Views)
