VI Analyzer
Hi
I am analyzing a VI (not using VI Analyzer) but using VIs.
For this, I am using VIAn Easy Analyze.vi for analysing & VIAn Easy Report for generating report. Now if i select Report Save type HTML or  ASCII then the result is saved in an unknown format not in the defined format.
please tell me what should i do to get the saved report in the desired format.
Raman
(3,084 Views)
I've never had a problem saving to ASCII or HTML reports with the Easy Analyze/Report VIs.  Are you giving the file a proper extension (.txt or .html)?  Check out [LabVIEW]\examples\VIAnalyzer\Easy VI Analysis.vi to see how to use the Easy Analyze and Easy Report VIs properly.  If you run this VI and it generates a report properly, then there's something wrong in your code.  If these suggestions don't help, attach a sample VI that demonstrates the problem and I'll take a look.
-D
(3,063 Views)
 Hi Darren
 I got one bug in my code. Now it is working properly.
Thanxs
Raman
(3,043 Views)
