VHDL-Code within Labview
Hi @all,
I've to admit, that I don't know Labview by now, therefor I've a
question on a topic I couldn't find a satisfying answer on in the internet.
My intention is to control test board using a digital I/O-card (no
FPGA). For the development of the test board (or more precisely the
chips on that board) a VHDL-Simulation has been used and a
VHDL-Testbench has been implemented.
I could synthesize the VHDL-testbench on a FPGA-Board, but I would
prefer to Labview and a digital I/O-card.
My question is: Is it possible to implement VHDL-Entities in LabView?
If yes, which LavView Modules do a need? I've read something about a
"HDL Interface Node" included in "LabVIEW FPGA Module" since v.7.1, but
I don't have the "LabVIEW FPGA Module" and I don't won't to program a
FPGA. I only want to use my existing (complex) VHDL-statemachine to
assign a few ouputs. Timing and speed are not a problem.
Is there a way to do that with Labview?
Andreas
(3,848 Views)
It sounds like your are asking for the ability to use LabVIEW to simulate your VHDL files.  You would then use these HDL simulation results as digital test vectors for a DIO board.  LabVIEW today does not natively include this capabiliity.  I believe you have a few options:
1 - Many VHDL simulation software packages can be called from the command line.  You could build a LabVIEW VI to call your simulation tool, run your testbench and parse the results into a digital waveform for your DIO board.  NI Multisim may allow for this as well (I'm not sure, so you'll need to do some Multisim research before going this route).
2 - Use the NI Digital Waveform Editor to import your simulation output as a test vector.  You can then verify the waveforms, make any changes, and save it for use with your DIO board.  Here is a link: https://www.ni.com/en-us/shop/product/digital-waveform-editor.html
3 - The HDL node available in LV FPGA allows you to synthesize custom HDL into a LV FPGA target.  If you prefer the DIO board as your interface, then this would not work for you.
Based on your notes, I would look into the Digital Waveform Editor's VCD importing feature first (option 2 above).
Which DIO board are you using?  And what do you use for VHDL simulation/synthesis for your test board?
-RB
(3,823 Views)
