VERIFY IF THE SIGNAL ACTIVATES
I am trying to make a program where if I sent a concrete number plot I want to see if the signal SVRE of the ring activates.
I attach the program.
Message 1 of 8
(4,487 Views)
Hi 99,
This ring control named "Ring" is just a control on the frontpanel of your VI. The item "SVRE" will be selected by the user of your VI…
To detect if the user has selected "SVRE" you can use a simple comparison of the ring value with 2, as this is the value chosen for the "SVRE" item.
How is the ring control value related to that EthernetIP stuff at all?
Message 2 of 8
(4,468 Views)
Sorry, I haven´t explained well.
I want to insert one number plot ( in the data to set), I want to write 0 2 0 0 0 0 0 0 0 0 0 0 0....
so when I write this I want to verify if  the case 2 of the case structure, which corresponds to SVRE, is activated.
Message 3 of 8
(4,462 Views)
Hi 99,
So you send this "data to set" to another device (by EthernetIP). Then you receive an answer from that device.
In the next frame a ring control on the frontpanel is read and it's value is used to select a case.
When you want to verify the user of your VI has selected the correct case then you need to place some code inside this case, like a OneButtonDialog…
(I still don't get what you want to achieve with this ring control and the EthernetIP stuff.)
Message 4 of 8
(4,452 Views)
Yes, that´s it. I send the "data to set" to another device. ANd what I have to see in the answer of the device in the "data received" is 2 64 0 0 0 0 0. And I know that this 2 64 0 0 0 0 0.... corresponds to the case 2 of the case structure.
I hope I have explained better myself.
Message 5 of 8
(4,447 Views)
Hi 99,
then why did you create this ring control?
What is it good for when all you need to do is to compare the received answer with an expected answer???
Message 6 of 8
(4,426 Views)
What I have to do is to put in each case of the case structure the corresponding binary code of the number. For example I have to put in the case 2. 00000010
I put it just like an string constant?
Message 7 of 8
(4,422 Views)
Hi 99,
I don't understand what you are asking here…
You get an array of (u8) numeric values. Why do you think you need to write a "binary code" as selector value in the case structure?
Why do you think you need to use string constants???
(A numeric value is just a numeric value - its representation/formatting in the frontpanel is irrelevant…)
Message 8 of 8
(4,388 Views)
