VB .net remoting example and LV counterpart code
I'm trying to emulate a snippet of Visual Basic .net remoting code into Labview 8.5. I've attached a simple picture that shows the VB syntax and the LV counterpart backpanel. My problem is, that after the Activator node, I don't see any of the methods available. Perhaps someone has a suggestion or comment. thanks....
(3,416 Views)
Hi Jim77215,
I do not see the class ns_ECTMS.ECTMS for the .NET object. Is the assembly called ns_ECTMS? If so, where did this assembly come from? Could you please provide it?
(3,357 Views)
Attached is a zip containing the .net assembly. When I start the server, then run the LV client, it dies on the To More Specific Class node. In fairness, Peter Lamb is also looking at this issue. However, I've been having trouble sending the attachement to him via  email.
(3,341 Views)
Please see this thread for continuation of this topic.
(3,319 Views)
