Usings VI to take Spurrious Table off of an MXA
Hey all,
I am having a problem with my Agilent MXA N9020A. I have a VI that puts it into Spurrious mode. It gives it its range of frequencies and then the Spec An gives me all of the locations of those spurs in a table on the Spec An. Is there a VI that can take the table of the Spec An and display it? I have looked through the VIs that came with the equipment but no luck unless I missed in the batch. Any suggestions would be wonderful.
dlovell
(2,737 Views)
Hi dlovell,
Are you using the VIs from the instrument driver for that signal analyzer? If so, which VI are you using for spurious mode and have you taken a look at the "read measurement" VIs that are included with the driver in the Data folder? If not, which set of VIs are you referring to and where did you get them?
James D.
(2,716 Views)
Hey,
The VI's I am using come from the library that came with the equipment. Here is the VI I use to put it into spuriours emissions mode and set up my parameters.
dlovell
(2,709 Views)
Hi dlovell,
The subVIs included in that VI are the same as the instrument driver provided on ni.com/drivers/idnet. Somewhere in that library that you have you should have VIs with the title "Read Measurement....vi". They will, however, need to be implemented as subVIs in a VI that combines some of those other subVIs from the library to accomplish the task of reading data from the Spec An. If you cannot find these VIs, then you can download the instrument deriver provided by NI at the following link:
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=9531
James D.
(2,692 Views)
