Using the %src argument in Installer>Advanced
I am attempting to use the %src argument as provided by the Application Builder > Installer > Advanced. The .exe that I execuate after installation attempts to read this command-line argument (using the CIN provided in NI Knowledgebase), but instead of returning the path that I expect, it returns simply the text string "%src". Has anyone else run into this?
Thanks.
(2,580 Views)
If you are using LabVIEW 6.1, the arguments changed but the documentation did not. Take a look at KnowledgeBase entry 2FJA5PXC
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/86256a47004e16d186256b0a005e4327?OpenDocument
(2,580 Views)
