Using the general error handler on an embedded rt target
I would like to know how the general error handler can be best employed with Labview RT on a Compact Fieldpoint controller.  Clearly no dialogue options are valid so how can error information be accessed remotely - is there an error log file available on the controller?
(3,156 Views)
I think there are plenty of ways to handle errors with Labview RT on a Fieldpoint controller.
Usually I use the general error handler vi to catch the error and get the error message (sure, no dialog), then write the eroor message into a log file (ordinary text file created on the controller), and/or send the eroor message through TCP/IP network to the host. You can use FTP to open, read and tranfer the log file at host. Hope help.
Xu
(3,146 Views)
Yes you can view your errors anytime using ftp.
Seamus
(3,127 Views)
