Using the cFP controller with only LabVIEW and FIELDPOINT software but no LabVIEW RT
I have a cFP-2020 controller and cPF-AI-100 modules which I intend to use in a small project. I do have LabVIEW and FIELDPOINT software but I dont have LabWIEW RT software. Is it possible to use the cPF controller with only just LabVIEW? if yes, I would like to be advised how. Thanks
(2,653 Views)
Dear Chuma,
It is not possible to set up your system without Labview realtime module.
There are system integrators who can build a executable for you. You can search for a alliance member by using the following link; https://www.ni.com/partners/s/?language=en_US Or call your local NI branch office. But if you are planning to do more realtime projects in the future this wouldn't be costs effective.
Another option is to use compact fieldpoint pc controlled backplane (so there has to be a PC to control your compact fieldpoint system (not deterministic)). You can do this by using the compact fieldpoint ethernet backplane; https://www.ni.com/en-us/support/model.cfp-1804.html
Good luck with your project, and please let me know if there are any questions,
Martijn
Martijn S
NI Netherlands
(2,634 Views)
