Using the XY Positions of Cursors from Intensity Graph
Hey all,
I have an application that outputs an intensity graph. I have two cursors on the graph that I use to make a box around parts of it to "zoom in". Right now, I have to manually type in the X and Y positions of both cursors into numeric control boxes in order to utilize them on the back panel. Is there any way to utilize the numbers without going through typing them into numeric controls each time?
LANL13
(2,722 Views)
Update: I realized that I can use property nodes to get the X and Y positions of a cursor. However, how do I pick if the node corresponds to Cursor 0 or Cursor 1? Right now they just automatically go to Cursor 1.
(2,717 Views)
Accepted by topic author LANL13
You almost have it, just use the ActCrsr property to set the Active Cursor before reading the values.  Property nodes operate sequentially from top to bottom so Write the value to ActCrsr on the top, then pull down and add the Cursor Postion properties.
Standard workflow you will get used to when using properties with graphs.  Set active cursor/plot then read/write properties of interest, often this is done in a For Loop.
(2,707 Views)
I don't quite get how to utilize ActCrsr. Could you expand a little?
(2,705 Views)
Nevermind. I got it. Thanks!
(2,697 Views)
