Using the OK button to set different configurations
I want to use the OK button to allow the user to select the correct configuration. For example, if the user wants to use configuration 1, then the user can push the OK button to set configuration 1.
(2,502 Views)
if i understand you correctrly, you have number of configurations, and one of them user can select.
So, see attached example.
(2,502 Views)
