Using the NI TPC 2006 to control a solar tracker
I have a NI TPC 2006 Panel and a solar tracker. The solar tracker is controled using a offline web page containing some javascript that uses a dll library. The web page is on a PC and i connect the tracker using a USB or a Com port and then make the modifications from the interface on the web page. My question is: is there a way to copy the offline web page to the NI TPC 2006 Panel and use it to connect to the solar tracker instead of connecting the PC to the solar tracker? Dose the NI TPC 2006 Panel suport javascript so that i don't have to always connect the tracker to the PC?
Thx
Alex
(2,146 Views)
Alex,
Are you going to try to integrate these dll calls into your LabVIEW program or will the communcation with the solar tracker just be limited to the javascript code?  If the communication is just going to be between the solar tracker and the html code, the question is essentially a Windows CE question.  Have you tried hosting the javascript from the NI TPC 2006?  If so, are you running into any issues with it?
Zach C.
Field Engineer
Greater Los Angeles
(2,118 Views)
