Using the LabVIEW (PDS), version 6.0, I cannot find the "Application Builder".
I use the LabVIEW Professional Development System, version 6.0. However, I cannot find the "Application Builder" in the "Tools" menu.
How can I install this toolkit from the CD?
Thanks.
(2,980 Views)
Interesting, mine installed automatically. It was not an option. I would try re-installing. It should show up in the "Tools" menu as "Build Application or Shared Library (DLL)..."
Rob
(2,980 Views)
Hmmm... The App Builder is located in the project folder:
project\prodisttool.llb\build application.vi
Make sure this LLB is in your project folder. Also... have you changed the location of your "Library folder" under tools>options ? LabVIEW looks for the project folder inside your "Library folder" whose default is usually something like this on a PC:
C:\Program Files\National Instruments\LabVIEW\
So the App Builder should be at:
C:\Program Files\National Instruments\LabVIEW\project\prodisttool.llb\build application.vi
If you changed your Library Folder, LabVIEW might not be able to find it, and then you won't see it under Tools
http://www.medicollector.com
(2,980 Views)
