Using the Internet Toolkit
I am able to successfully send an e-mail using the Internet Toolkit; however, the "message" is always empty (the text string wired to message in my VI does not appear in the e-mail). I have tried different types of Email VIs and I always have the same problem. I am running Windows and I have charset=us-ascii. What am I missing?
(3,199 Views)
As I recall this was an old bug that I patched in my code some time ago. Unfortunately I don't remember what the exact problem was. Send me your email address and I'll send you a VI that I know works.
Also, are you needing to include attachments?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,199 Views)
Thanks for the info. Yes, I am including attachments. My e-mail address is kelmhurst@watsonhenry.com.
(3,199 Views)
ELMHURST,
Do the shipping examples in \examples\internet\ftp_smtp.llb work to sent an e-mail message? This is where I would start. If these examples work fine, then it is something in the code. If they do not work, then I woulg go back through the Internet Toolkit manual and make sure that everything is configured properly.
Another possibility is that the toolkit does not put a blank line between the header and the message body (tat is fixed a future version of the toolkit). Try adding another \r\n at the end of the format string in SMTP Send Message Header.vi and see if that fixes things.
Randy Hoskin
http://www.ni.com/ask
(3,198 Views)
