Using the Formula Node for PDA
Thanks Joe,
I am using labview 7.0f1 and windows 2000 professional. I am able to run the VIs successfully in the windows environment. I get the error when i try to build the executable for the PDA. When I click on build for PDA the error screen i attached earlier shows up.
Prasad
Message 11 of 15
(2,013 Views)
Prasad-
Thanks for sending the files.
Ok, I have some news. I've been looking into the issue for the past several hours with the help of our R&D PDA team, and your issue seems to be unexplainable. I was able to successfully reproduce your error on my machine, and the error goes away if I try to build the shell (CDmain) file without including the formula node subVI.
We are going to investigate the problem further and determine why the formula nodes are causing issues when building the PDA application.
In the meanwhile, the only solution I can propose is to use LabVIEW to write your C++ code. Fortunately, the function calls that you make (for loop and count increm
ent) are functions that LabVIEW offers. This translation effort should be quick, because your C++ code appears to be pretty short and basic.
I will keep you updated as our investigation continues. Until we find the source of the problem, I am available to you for help in translating the formula node code into LabVIEW code if you need any assistance.
Again, I apologize that this has inconvenienced you, and I'll be here for help until the problem is solved.
Best Regards,
Joe Des Rosier
Message 12 of 15
(2,013 Views)
Hi Joe
Thanks for all the help. I will try and rework my code in LabView. Hopefully the issue can be resolved.
Thanks again for all the help
Prasad
Message 13 of 15
(2,013 Views)
Hi Joe
I think I figured out what the issue is with the formula node. I was looking through one of the help documents and I discovered that arrays are not supported in the formula node. Since I was using arrays in the code that may have caused the problem.
I did rework my code using labview and everything is fine now.
Thanks for the help
Prasad
Message 14 of 15
(2,013 Views)
Prasad-
...glad you got the code working. I wish one of us had found that help document earlier, but at least things are back on track.
Best Regards,
Joe Des Rosier
Message 15 of 15
(2,013 Views)
