Using setupapi to uninstall hardware
During production test, we test usb products.
Problem is, everytime we connect another UUT, it creates another entry in the registry.
I believe it is possible to use the windows setupapi to uninstall devices, and so clear the
registry in the correct way.
Anyone ever used this or have any advice?
(3,323 Views)
Hi Morngoose,
Good afternoon and I hope your well today.
The usb device information is stored under HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\USB - you can then delete these - see this external link titled
Removing USB Windows Registry Keys.
Another method would be just to make a backup of the registry and then replace it at the end of the test.
I would also like to suggest you could take a read of the following knowledgebase, What Registry Changes Result from Installing or Uninstalling Hardware or Software [broken link removed; article no longer available]? It explains you can do a check on what files change during an installation, and you can just delete these at the end.
The steps you need to take are something like,
  1. Go to Start » Run and type regdt32. Click the OK button. This will launch the Registry Editor.
  2. Navigate through the Registry tree as follows: HKEY_LOCAL_MACHINE » System » CurrentControlSet » Enum » PCI. You will see several Registry Keys in this folder, which look like this: VEN_####&DEV_####. These are vendor and device codes, respectively.
  3. The National Instruments vendor code is 1093, so remove the Registry Keys that are of the form: VEN_1093&_DEV_####. If Windows does not allow you to delete a key, you may need to change your user permissions.
I hope this information helps, and please post back to discuss your issue further.
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(3,303 Views)
