01-17-2022 08:53 PM
Hi All.
My question is pretty general. I have a sub vi (say aaa.vi) that has data items that must remain present between successive executions (i.e. it uses shift registers on a while loop). However there are multiple areas in the project where these persistent variables are to occur.
My current approach is to create aaa.vi then copy to aaa_1.vi and aaa_2.vi. Then use these 2 secondary vi's (with the same program !), with their different sets of persistent data. Note that with the naming, I know which persistent data set is being used.
What is the recommended way to achieved this same end (with LabVIEW) ??. With my approach, a change to the aaa.vi program implies a coping process (too the clones), which is not automatic.
Regards JC........
Solved! Go to Solution.
01-18-2022 01:25 AM
If you make the subVI reentrant, each instance will have its own persistent data.
01-18-2022 06:22 AM
Attention: LabVIEW does not guarantee that a caller will always get the same clone. You have to use preallocates clones if your callers use data from the SubVI.
01-18-2022 10:25 AM
Yes, of course. That was implied. 🙂
(When I learned LabVIEW, shared clones did not even exist...)
01-18-2022 10:48 AM
When you learned LabVIEW, Event Structures didn't even exist. 😄
01-18-2022 11:51 AM
🤣 I guess that puts me in good company. How did we ever program without the event structure (don't answer that, I remember all of the polling).
01-18-2022 11:53 AM
... and there was no UNDO! (Motto: think twice, wire once!) 😄
01-18-2022 06:27 PM
Thank you ThomasHenkel.
With this subject I have to think about the different type of memory involved. To me these are;
Program space
Temporary data space
Persistent data space.
The option of Preallocated Clone Reentrant Execution is a possibility. The Persistent data would need to be managed separately with a reference to it. And then you need to be careful about multiple execution colliding with the integrity of the Persistent data.
The option of Shared Clone Reentrant Execution is similar to the Preallocate option above. This has less control of what data is used.
The option of Non-Reentrant Execution is the safest. This is what I use with my initial post which seems to be the best for the situation involved.
Changing the program needs to be performed in multiple locations. This ensures the mapping to the different sets of Persistent data. The name of the program also relate to this mapping. The single execution at a time helps with Persistent Data integrity.
Regards JC.......
01-18-2022 06:41 PM
Program space
Regards JC.......
I think you missed the point of altenbach’s post. The pre allocated clones will be persistent for each instance. Assuming that you’re only calling the ci once for each datatype then you already have your solution.
I generally prefer non-reentrant as well and would keep the data at a higher level, likely as part of a class.
01-18-2022 07:07 PM
"Assuming that you’re only calling the ci once for each datatype then you already have your solution."
I am not making this assumption. I want to call the vi multiple times for the different Persistent data sets from different locations.
I generally have multiple activities/executions (with a ctl as a parameter) for the different Persistent data sets.
Regards JC.......
