Using "New VI Object" function to create a while loop with a wired conditional terminal AND a "wait (ms)" function
when I do the above, the VI only contains the wired conditional terminal. If I remove the code to wire the conditional terminal, the "wait (ms)" appears within the while loop. So there's obviously a conflict between these two. Is it even possible to do both within one while loop and if so, how?
Thanks.
(2,919 Views)
Hello SnowLord,
VI Scripting is a NI Labs Product, like mentioned here:
https://www.ni.com/en/support/downloads/tools-network/download.labview-vi-scripting.html
it is only supported through the API Group.
You should post your question there.
Best Regards!
Moritz M.
(2,890 Views)
I replaced your reference control with this:
When I run it I get a VI with this:
It appears to work correctly for me.  Perhaps I misunderstood your situation?
Jim
(2,886 Views)
Scripting has been an official part of LabVIEW since LV 2010 (accessible through the options dialog and documented). There's no problem with the LV APIs group, but there's no reason it shouldn't be supported here as well. I would suggest you update your procedures to reflect this.
___________________
Try to take over the world!
(2,876 Views)
