Using notifyicon in an executable shuts down application
Partha,
I don't think the .NET framework was available for 7.1, so it won't work for that version.  You need at least 8.0 and you have to have .NET installed on your system.
- tbob
Inventor of the WORM Global
Message 11 of 12
(597 Views)
Actually, that's not true. You can use .NET with 7.1. However, if you're using .NET 2.0 you should be using 7.1.1f2, as that version fixed some issues with .NET 2.0.
Message 12 of 12
(591 Views)
