Using multiple channels with DAQmx reference trigger (analogue edge)
Hi Chris,
Running the original code with 4 channels wired the 'task/channels in' (my global virtual channels named - AnIn 1:4) with AnIn 1 named as the 'source' results in the following error:
Code: -200264
with the text:
DAQmx Start Task.vi:71<append>
<B>Property: </B>Ref.AnlgEdge.Src
<B>Corresponding Value: </B>AnIn 1
<B>Number of Channels in Task: </B>4
<B>Task Name: </B>AnIn 1:4
Message 11 of 14
(1,000 Views)
I believe this should help. If you wire your trigger signals to APFI lines and use those as your reference triggers you should be able to acheive the behaviour you're looking for.
Why do I get Error -200264 When Performing Analogue Reference Triggering?:
http://digital.ni.com/public.nsf/allkb/1CD33848C0CB0FC98625711400630A9D?OpenDocument
Best Regards,
Chris
National Instruments - Tech Support
Message 12 of 14
(996 Views)
I read that file that you provided a link to. It's unfortunate that I can't set the number of pre-trigger samples to 0 (I have to set it to a value not less than 2) and simply record post-trigger samples at the rate I want. That would allow me to wait for a trigger on any one of the analogue input lines prior to recording and data and avoid the cause of the error.
I only have APFI0 available on my 6251. I'll have to think of a way that I can wire and select from 2 separate differential voltage inputs on that single line as the sorce of my trigger.
Message 13 of 14
(994 Views)
From the look of things, it will may not be possible to implement a hardware solution with the kit you've got. You will either need different or additional hardware such as some sort of switching circuit for the APFI line.
Chris
Message 14 of 14
(991 Views)
